First time posting after recomendation from another forum.
Just bourght a new- to me- landrover TD5 and had an oil test done the results are below. It's only had one dealer oil change and the sticke says mobil 1 so i assume it is Delvac 1 ,recomended by LR, which is what the test is based on. Since the report I've changed the oil to Castrol super R 0W40 and the two filters. I intend to have another test done at the end of the march by which time i should have clocked aboth 5,000Ks on the new oil. Of interest TD5's have been know to have leaky injector seals or worse cracked heads.
The **viscosity and fuel** were found on the test to be out of kilter and it was recomended that filters and oil be changed; now done
Would appricae any comments.
Vehicle
2002 Landrover Defender
5-CYL diesel 2.5 Lt
turbo direct injection
Air cooled inter cooler
Oil Mobil Delvac 1 - 5W40
Ks traveled on oil 11,000Ks
Total K vehicle traveled 31,008
Filters -standard
1 -Centrifugal Original -from new
2 -Full flow element changed at 20K service
Metals - PPM Analysis
Aluminum -AI 7
Copper -CU 7
Chromium -CR 2
Iron -Fe 35
Lead -Pb 5
Tin - Sn 2
Contaminants/additives -PPM-
Silicon -Si 8
Sodium -Na
Physical Tests
Water -by % FTIR Viscosity -cSt, 100 degrees C **9.2**
Soot % 0.3
PQ Index 24
Fuel % **5**
Vehicle
5-CYL diesel 2.5 Lt
Filters -standard
Aluminum -AI 7
Copper -CU 7
Chromium -CR 2
Iron -Fe 35
Lead -Pb 5
Tin - Sn 2
Silicon -Si 8
Sodium -Na
Physical Tests
Soot % 0.3
PQ Index 24
Fuel % **5**
