Delvac-1 5w-40 VW 1.9L 9981 miles
Peoples Republic of Cal, Central i Coast Provance
Delvac-1 5w-40
Cat SOS Lab
Miles on oil: 9981
Miles on motor: 59966
Vis @100C 16.2
Al 9
B 125
Cr 6
Cu 7
Fe 117 !!
Pb 5
Mg 601
Mo 1
Ni 6
Si 11
Na 1
Sn 2
Zn 1334
Soot 1.9%
Water 0
Fuel 0
Anti-freeze 0
TBN 9.0
Car is driven about 90% highway and 10% creep and go.
This is by far the best Delvac-1 sample for this car.
Well, that awful number is an improvement over the one before! Something was grinding away on the inside. A compression test showed that everything was within specs. All four cylinders were above 500 psi. A front crank seal had failed. Perhaps the Iron was from it grinding away on the crank.
