Just as I promised here are my TDI results using Schaeffer's 7000 15w-40. This vehicle is a daily driver (2500 miles a month) used for 90% highway at or over the posted speed limit of 70 mph. OEM filters. Only modification is to the EGR duty cycle. No make-up oil. No oil additives. Schaeffer's Soy Shield diesel treatment at a 1 oz per 3 gallons ratio.
Dyson Analysis
Customer Name : Neil Womack
Oil Brand/Weight : Schaeffers 7000 15w-40
Type Equipment : VW Golf TDI 2003
Miles/Hours on oil : 4770
Total Miles/Hours : 10246
Results ppm/%
Wear
Copper 3
Iron 18
Chromium 1
Lead 1
Aluminum 4
Silicon 4
Tin 1
Additives
Moly 83
Sodium 3
Magnesium 15
Zinc 1286
Potassium 0
Phosphorus 1132
Calcium 3272
Physical Properties
Water negative
Fuel negative scale negative,trace,positive
Antifreeze negative
Soot/solids 0 NONE !
Oxidation 35 scale 0-199 17%
Nitration 15 scale 0-199 7.5%
Sulfur 33
TBN 6
Vis@100 C (cSt) 13.8 perfect SAE 40w starts at 14 -16 cSt by tech
sheet
TAN na
edited to remove Terry's comments
What do you think?
[ July 10, 2003, 04:51 AM: Message edited by: Patman ]
Dyson Analysis
Results ppm/%
Wear
Copper 3
Iron 18
Chromium 1
Lead 1
Aluminum 4
Silicon 4
Tin 1
Additives
Moly 83
Sodium 3
Magnesium 15
Zinc 1286
Potassium 0
Phosphorus 1132
Calcium 3272
Physical Properties
Water negative
Antifreeze negative
Sulfur 33
TBN 6
sheet
TAN na
What do you think?
