Trending Analysis
Roxboro, NC
I thought it would be good to show some trending from Shell Rotella 15w40 through two changes on Schaeffer Supreme 7000 15w40. This is a ITC 5000 Dump Truck. about 300-350 miles a day (short trips)
----------Rotella-----Supreme 7000---Supreme 7000
Miles/unit--119,853-----135,232-------170,742
Miles/oil-----9,897------15,382--------17,771
Copper---------2-----------3-------------2
Iron----------25----------37-------------24
Aluminum-------1-----------2--------------1
Lead-----------2-----------6--------------0
Molybdenum-----0----------100-----------155
Phosphorus---1325---------1103---------1307
Zinc---------1485---------1219---------1527
Silicon---------1-----------4------------2
Vis.---------14.32--------14.83---------14.39
sulfur--------37----------15-------------16
oxidation------0-----------9--------------5
nitration------2----------10--------------6
soot----------21----------32-------------11
-------------------------(#1)-----------(#2)
#1 Lab suggest increase oil drain to 18,500 miles
#2-Lab suggest increase oil drain to 21,000 miles
comments welcome
[ August 11, 2002, 04:46 PM: Message edited by: David ]
I'm curious how it's possible on that first analysis, to have an oxidation of zero?
Also, it's interesting to see more moly on the very first change with Schaeffers. I would have thought it would be less on the first interval, due to the moly plating up, then on the second interval it would show more moly.
quote:
Originally posted by Patman:
I'm curious how it's possible on that first analysis, to have an oxidation of zero?.
Patman, It had to be a mistake,I think
quote:
Also, it's interesting to see more moly on the very first change with Schaeffers. I would have thought it would be less on the first interval, due to the moly plating up, then on the second interval it would show more moly.[/QB]
The moly was a mistake on my part, it was 155 not 73
Thank you for pointing that out! I will edit the post.
It's yet another great analysis for Schaeffers! I'm getting more and more excited about
putting this oil in my car. I've only got 1645 miles to go!
Those are very good numbers. I would have liked to see the Shell run for 15,000 + miles to see what it would have looked like. At 9,800 miles the Shell looked very good also.
