AMSOIL 5W-30 in '98 RAM 6L Cummins
San Antonio
Here's a long-term oil sample. Ya'll enjoy!
1998 Dodge Ram 2500, 5.9L 6 Cyl Cummins
AMSOIL 5W-30 HDD, AMSOIL dual remote full flow/bypass
Filters change on schedule; 4 gallons make up total
147,000 miles on truck and oil
code:
Nov 99 Feb 00 Aug 00 May 01 Mar 02
Mileage 53197 70705 93204 113456 147045
Fe 114 120 74 56 49
Cr 4 4 2 2 1
Pb 9 10 7 4 7
Cu 18 20 11 152 219
Sn 1 1 1 2 2
Al 11 19 0 7 11
Ni 1 1 1 0 2
Ag 0 0 0 0 0
Mn 2 2 1 1 2
Si 15 13 9 6 6
B 35 20 27 25 29
Na 2 1 2 0 0
Mg 29 53 37 34 49
Ca 4357 4341 4228 4321 4333
Ba 0 0 0 0 0
P 1269 1236 1125 1285 1257
Zn 1347 1349 1382 1342 1357
Mo 3 0 1 0 0
Vis@100C 10.5 10.6 10.5 10.8 11.6
Soot All
Oxd 30.0 10.0 12.2 20.0 12.2
Nox 10.0 10.0 10.0 14.3 12.9
TBN 12.1 12.5 12.8 12.7 12.9
Water all
Fuel all < 1.0
Comment: Copper possible leacheate from oil cooler/lines
[ December 10, 2002, 08:30 AM: Message edited by: Andy H ]
I assume that the oil cooler was added in Aug 00, but I don't see any benefit to your oil or engine from it. It's interesting the way your Fe is coming down. Why? And no Al in Aug 00. Your miles must be predominantly highway.
Hi Jay,
No cooler added; stock except for bypass. This was the second oil fill for the truck which was still breaking in.
The longer it goes the better it gets. I guess my concern would be that the Cu could be coming from the crank thrust brg.
147k miles on the same oil?!
How often do you add fresh oil?
How often do you change the oil filters?
TexasTDI,
The folks are using the AMSOIL dual remote filter which includes an SDF full-flow and a bypass cartridge.
The letter I got from the customer said they changed the filters at 'regular change intervals'.
The spin-on would be about 6 months, the bypass about every year at a minimum. I expect they changed more often as they ran about 50K miles per year. They used about 5 quarts of makeup oil per year for 3 years and three months.
Andy
code:
Fe 114 120 74 56 49
Cr 4 4 2 2 1
Pb 9 10 7 4 7
Cu 18 20 11 152 219
Sn 1 1 1 2 2
Al 11 19 0 7 11
Ni 1 1 1 0 2
Ag 0 0 0 0 0
Mn 2 2 1 1 2
Si 15 13 9 6 6
B 35 20 27 25 29
Na 2 1 2 0 0
Mg 29 53 37 34 49
Ba 0 0 0 0 0
Mo 3 0 1 0 0
Soot All
Water all
Fuel all < 1.0
Is this Amsoil's 3000 series oil that can also be used in gas engines?
quote:
Originally posted by ben walker:
Not really suprising as the Cummins is a hell of a good motor.
Ben,
I think you would have to look far and wide to get an argument to your statement.
"Ben,
I think you would have to look far and wide to get an argument to your statement."
You couldnt pry mine out of my hands.
My wife bought a f250 superduty to tow around her horses, nice truck but the Cummins is just the best diesel engine in the pickup market by a long shot.
