Here is my latest analysis of Amsoil 5W-30 Heavy Duty Diesel Oil after 15,000 miles in my modified Cummins 24 valve engine. The engine has been dynoed at 380HP/850ft-lb torque at the wheels, so it is hardly stock. I use Fleetguard Stratapore full flow filters and an Amsoil bypass filter.
Glycol.....Neg
%Water.... %Fuel..... [email protected]
%Solids.....N/A
%Soot..... %Oxd.......16.7
%Nox.......10.0
TBN........12.7
Iron........26
Chromium.....0
Lead.........7
Copper......13
Tin..........1
Aluminum.....8
Nickel.......0
Manganese....2
Silicon......4
Boron.......34
Sodium.......0
Magnesium....5
Calcium...4289
Barium.......0
Phosphorus1241
Zinc......1341
Molybdenum...0
Titamium.....0
Vanadium.....0
Cadmium......0
Air filtration is an Amsoil oiled foam filter.
Glycol.....Neg
%Solids.....N/A
%Nox.......10.0
TBN........12.7
Iron........26
Chromium.....0
Lead.........7
Copper......13
Tin..........1
Aluminum.....8
Nickel.......0
Manganese....2
Silicon......4
Boron.......34
Sodium.......0
Magnesium....5
Calcium...4289
Barium.......0
Phosphorus1241
Zinc......1341
Molybdenum...0
Titamium.....0
Vanadium.....0
Cadmium......0
