Tried to start my Suburban today and it would turn over fine but would not fire at all. Squirted some starting fluid to see if a fuel or ignition problem and it fired for a second, so its a fuel problem. The vehicle has gas and the filter is not that old. Where do I start looking. Is there a fuse for the EFI or fuel pump, etc. This is the older EFI where they just replaced the carb. with an EFI system.
