I have a 1992 Mazda B2600i truck with a Japser engine. The engine has apx. 8500 miles on it now but the injectors are original w/ 190,000 miles on them. The truck exibits a light ping on acceleration and when pulling long freeway grades. I put 89 mid grade in and it seem to help reduce the pinging but its not gone. Timing is @ 5 deg. advance set w/ vac line plugged and idle set per spec. I use FP every tank. What should I check? I think truck has a knock sensor. Plugs, wires, fuel filter, even the distributor are all new. All basic stuff is in order. Is it time for new injectors? Should I just step up to premium fuel. It seems like this would be a banaid fix for something else. The truck should operate on regular. Thanks
snoboy
snoboy
