From a preventative maintenance standpoint, when should radiator hoses (upper and lower) be changed ? I have 97,000 miles with the original hoses ( made by Gates). I check mine periodically for "sponginess" and cracking, and have observed no obvious problems. However, Murphy's Law being what it is, a hose failure will always occur at the worst possible time in the worst possible place.
I am going to change out my Dexcool at 120,000 (last changed at 60,000) and it would seem logical to change the hoses then. Is that pushing my luck?
