Hi All
Happy New Year
I have this most puzzling problem. When the temperature is very cold (-20 degC or more), I get a small coolant leak from the block, just under and behind the throttle body. This only happens on the first start at cold temps. After the engine warms up the leak stops
This does not happen when the ambient temp is above 0 degC. I have no idea what's going on. The last UOA was neg for glycol. The engine is a GM 3800 with ~100,000 km on it. Anyone have any suggestions,clues, advice.
Thanks,
Bry
Happy New Year
Thanks,
Bry
