Hey all:
1991 Acclaim 2.5 3-speed, 133,000 miles. Car has been running pretty well, getting around 25ish MPG, pretty smooth on the highway. Gauges read normal, computer has no codes. Basically, no indication of any problems. Tuneup done about 1 year ago, regular oil changes, 87 gas (some knocking under load). Timing belt and tensioner changed about 9 months ago. Front and passenger mounts just replaced. Revs fine, though a little weak on the upper end.
All of the sudden today, I started it up, and it ran really rough. Engine shaky, harder to rev, weaker. Basically, a totally different car. This was not the first start of the day, it was about the third.
I have tried different known good (albeit old) spark plugs, I have flipped the contact sides of the wires in the cap, I even cleaned the rotor contact. I tried running the car missing one wire for each start. Thinking that there was a bit if crud somewhere, I even ran some water slowly through the brake booster hose.
I have to admit, I am a bit lost here. Please help. I reeally need this car to be running well, because I use it to get to school.
I eagerly await all suggestions and ideas.
David
David
