Looks like my Cat Convertor is on the edge of being plugged.
This has been ongoing for quite a while with low performance once the engine has been run for 100+kms and the engine is really up to temperature.
Also the idle is really crappy after long trips only or after the engine has been really driven for a while.
It is completely tuned up but it is still pinging under light load and just boggy unless you floor it.
The exhaust coming out of the tailpipe is very hot and you can only hold your hand near the tailpipe for about 1-2 secs.
Had a cat back pressure tested but the dumb morons at the dealership tested the back pressure after the truck has been sitting for 30+ minutes.
No wonder they didn't detect a problem. The cat wasn't warmed up yet.
