It doesn't sound normal to me unless you made several hard stops, just before. Are the brakes dragging for some reason? Chock it good and try jacking a wheel up with the engine running. With disks, there will always be a little resistance to turning a wheel, but not much. How does the brake pedal feel? It should travel a very short distance with almost no resistance. There should be at least a little play between the pedal and the clevis for the master cylinder.
I find it unlikely all 4 calipers would stick at once. No chance of a little power steering fluid in the master cylinder? Recheck any work done recently to the brakes.
If you don't find anything, post back with more details.
