Hello, I have a 2002 Toyota Camry V6 w/38K; the problem I am having: I was cleaning my engine and decided to remove the intake so I can reach the back of the engine. When I remove the intake from the throttle body there was an excessive amount of oil in the intake and throttle body. I took it to Toyota and they told me this is normal. I have changed the PCV valve (which is connected after the throttle body) I also have leaky valve covers and black dry soot on my exhaust tip (always), and they also told me this was normal. Is this correct? I know if I have dry soot on the exhaust, it means that my car is running too rich.
