I just repaired a broken wire to the headlamp and replaced the battery in our 2000 Grand AM. Started it up and parked it outside overnight. Now the ignition key won't turn. Key works o.k. in door. Tried second key, same result.
Checked fuses. Dealer said check battery connection - seems o.k. (lights, etc, work, bell dings when put key in). Is this just coincidence? Need new ignition switch?
HELP ME HELP MYSELF!!!!!!!!!!!!
