I've been told that turning your ignition key to the ON(II) position for a few second before starting allows the electronic fuel and oil pumps to prime. You can see this as fuel gauge starts to register after a few seconds. Is there any advantages to this with the oil system allowing it to pre-lube faster when starting?
