Hi guys,
What is the best way to remove an old, stubborn gasket that is sticking to the surface. This is a general question and can apply to any gasket, i.e. water pump, valve cover, intake manifold, etc.
I've seen many people use a scraper to get most of it and then they clean up the surface with scotchbrite. This works well, but I won't use scotchbrite in an area that opens to the crankcase because it leaves abrasive particles in my engine
My current procedure is to scrape the old one off with a freshly sharpened plexiglass scraper, then I soak the remnants with something, usually WD-40, then I scrape the rest off. I wipe away any residual with a shop rag. This gets maybe 90% of the really stubborn ones, though. Sometimes I just leave the other 10%, rather than gouge up the surface. If possible, I will stuff rags into the hole to block any gasket material from getting inside. But this can't always be done.
I'm interested to hear how some others here handle this job. I know most of us have been there!
Also what gasket compound, if any, do you use on the new gasket? For me, it depends on what I'm sealing; For cooling systems, say, a water pump, I will use some RTV silicone. For oil, I like a light coat of NAPA's aviation "form a gasket" on the gasket. Sometimes I use nothing at all.
I generally always use the compound that a service manual says to use, however, and I never "make" a gasket with some compound, unless that is what is called for. (some GM cars)
