Well, not really, but I am having trouble balancing the logical, disciplined coleslaw against the emotional, superstitious coleslaw. I have a couple of diesel powered boats. The older boat has Cummins 5.9B diamond things, and I have been using Mobil Delvac 1 and Napa antifreeze and life has been good. The newer boat has a couple of Yanmar LP STE engines (Toyota, light weight, high output)and life has also been good. I am using the same Delvac synthetic and Napa antifreeze, the only difference is that the Yanmars specify 125 hour oil change vs Cummins 250 and coolant change annually vs. every 2 years. I don't care about that. . .I am not in to extended oil change intervals or saving a buck on antifreeze. I just want to take care of the engines so I can run the **** out of them when ever I feel like it. (I have been getting Blackstone oil tests at every oil change and they have been coming out just fine.) So, like a naieve jerk, I cruise the internet and I find that I am doing everything wrong. . .Yanmar's can't run on synthetic oil or green antifreeze. . .Cummins shouldn't have this or that. . .but I've been doing it and life is/was good until all these little paranoid guilt trips in cyberspace by the minions in the peanut gallery. What is real???
