Please help me understand. If I am reading the specs correctly, the cSt@ 100c of Delvac 1300 15W40 is 15.6, and the cSt @ 100c of ESSO XD-3 OW40 is 15.7. I think this means that the ESSO is slightly thicker when the motor is at running temp. Why is it then that the Esso has 5lbs "LESS" oil presure than the Delvac? Should they not be about the same? I switched to the ESSO synethic for the winter and was very perplexed to find the oil pressue less right across the operating RPM. Can anyone explain? Roger
