quote:
Originally posted by Andy H:
Bob, Please stop the smoke! I'm not trying to sell anything. Didn't say you were. Just letting you know that I understand why you're so set on this issue due to your connection with amsoil, and I appreciate where you're coming from. You almost sound offended and or maybe even embarrassed about being an amsoil rep? Since I'm not a sponsor I'm not bound by your gag clauses either. Interesting you'd think that, as I don't believe I have anyone here gagged, ESPECIALLY YOU I drive a TDI and you recommended a product that DOES NOT meet the requirements of the manufacturer of the car. That didn't stop you from recommending the product even after you learned that that a synthetic oil is required. Excuse me Andy, but I haven't learned that synthetic oil is required first of all, but have learned YOU SAY IT IS. Bloody irresponsible.
I've read the items you link to. AGAIN I tell you you're suffering from an inability to see the issue at hand thru your blinders! Cummins hasn't changed their oil requirement because of ring sticking, have they? THEN WHY DO YOU INSIST ON DRAWING PEOPLE AWAY FROM THE SUBJECT? What do you feel you have to hide with these tactics?
Nothing, you obviously miss the point of this, YOU KEEP SAYING THAT A BLEND CAN't PERFORM LIKE A FULL SYNTH, I JUST SUPPLIED YOU WITH EVIDENCE THAT THIS ONE CAN HOLD UP TO AND MAYBE EVEN PASS SOME SYNTH's. That was the point of those, no smoke. Seems you thought I was using smoke an mirrors the last time we got into a debate over gear oils in the lower gear unit section.. You state that I use smoke, man, you'd think I like fire or something. Actually Andy, you obviously are very defensive as we are not trying to say what you're using isn't correct, nor am I saying that synth's is not the better choice, but I am saying and proving I might add that you are not up to speed on other lubes as you may think you are, and when you state an opinion as fact as you did with saying schaeffers wont work, then YOU are being "Bloody irresponsible" as you put it. As you can see on this site, we don't just believe people just because they say so, but because we look more into what it's all about.
I think it's great that you shared the FACT about higher piston ringland areas... I think it's great you shared the FACT that they use Castrol syntec.... I think it's great you have an opinion about Schaeffers... All of it fine and good.
Sell your products any way you wish - but at least tell your customers the truth and let them know that they're experimenting with their engine. Well, I see from some of your analysis you've provided that you have done a little experimentation with rotella, then moved to amsoil. Now, interesting you are so stead fast on where your at, based on what I seen, you did improve on the wear limits with the amsoil, but with only 5700 miles on amsoil, you seemed to have depleted down to b> Then at least it's their choice. Correct
I'm outta here. I thought you folks were smart enough to understand this issue. Thats correct, we do, you've seemed to failed miserably at this Andy. We understand that you have an opinion of what is or isn't going to work, As we do. We understand you're embarrassed to be recognized as an amsoil rep(why I have no idea as it is a good product). We understand you can't believe there's other oils beside a full synth that can perform as good or better than some full synth's. This is what boggles my mind is you're so closed minded even when the #'s support the evidence we show you. Of course I can go on what we do understand but I'll let it be as I don't want to go there.
I recommend the TDI drivers spend some time at tdi site where at least you'll get good info about your vehicles. And I don't own the TDI Site either. I know you don't, otherwise some 10 posts you had on there about this same subject wouldn't be disappearing from being deleted on there if it was yours. SAD, that you think they listen to you on there and yet try and support their site. At least Andy, I will have a dialog with you about my issues on your comments/ statements and up till now, other than you not understanding my issue with you was your factual comment about schaeffers, I've had no problem with what you say. I really don't even want to convince you to change, that's not what I am looking to do, nor do I want to change anyone else over from amsoil as I think it's a good oil and if some one is happy with it, then stay with it. As you pointed out though, it's their car/ engine. I just believe that you don't need to down grade another oil with out putting up some facts and those papers that VW put out, doesn't say Schaeffers anywhere, but dino oil in general.
This is why so many like this site as we work at seeing what is or isn't what it says it will do not by just speculating but doing oil analysis and such. Even you have done yours, and by looking at it, it shows you what you may or may not know, and when the schaeffers oil analysis comes out from a tdi, then you'll see for your self, that you may or may not be right. At that point, then either you or me is going to be able to say I TOLD YOU SO. NOW YOU'LL HAVE SOME EVIDENCE to back up what your saying or MAYBE You'll have some evidence that YOU WERE WRONG in just believing what you hear.
Anyway, enuf said.
