I'm fascinated that long haul trucks use multi-grade oils. Regardless of brand or type, multi-grade oils will lose viscosity over time due to polymer shear.
I can see where cars with frequent cold starts and short trips and frequent oil changes benefit from multi-grade oils, but a long-haul tractor engines run 8-12 hours minimum per cold start, and oil change intervals are in the 10's of thousands of miles.
Why don't long haul tractors run straight SAE-30 or SAE-40 depending on whether it's summer or winter? The single-weight oils are far superior from a lubrication standpoint. Inquiring minds wonder???
Regards, Gary in Sandy Eggo
