There is many people in the industrial world using the fine delo 400 40wt oil in many older diesel engines. The problem is that this oil is designed as a 4 stroke engine oil and not a 2 stroke engine.
Quote from http://library.cbest.chevron.com/lu...52d1e44144e815bb8825605900514696?OpenDocument
"Chevron Delo 400 oils are not recommended for use in DDC two-stroke engines."
Many boats (shrimpers and such), buses, generators, stationary pump engines and more are 2 stroke engines.
