My new 2005 Toyota Tacoma l4 engine auto transmission has no drain plug in the pan or dip stick for checking the level. The manual says the oil in the transmission is good for the life of the vehicle. Should I worry?
Oh man I didn't think yota would jump onto that bandwagon!quote:
I hope toyota doesnt charge $500 like volkswagon does for their so called long life atfs.quote:
No worries. They still spec Toyota T-IV ATF, which is widely avaliable at Toyota dealers for $4-$5/qt.quote:
They have a new one called WS-ATF used in 2004 and up Lexus LS430s, the 06 GS and IS, and any 6 speed application, and i also heard WS-ATF is speced on the new Tundra/Sequoia and 4Runner.quote:
Michael
I checked and the Tacoma still specs T-IV. Yes, you're correct that some of the new ones spec WS-ATF, but I double checked and the Tacoma is not one of them.quote:
Michael
Can one really safely use these generic ATFs in a ZF box for which ESSO is specified? I wish I knew ...quote:
... Jiffy Lube, YES Jiffy Lube will do it with the excellent GrpIII Pennzoil or Quaker State Multi-Vehicle ATF for $99.
Mike
John,quote:
Mike
Also, don't we need to drop the pan periodically for sludge cleanup and filter replacement?
By the way, I know a reputable local transmission shop which will pan-drop service a ZF for less than $300, not $500.
I'm slightly incorrect:quote:
Michael
Mike
Not worry, but maybe at about 50,000 miles take a sample of the warm ATF and send it to a testing lab. For $20 you'll get a report that says either to flush and renew it, or to keep it in and save your money. The WS ATF IS a very long life product.quote:
why not at 25 just to be safe.quote:
Ken
Why not just do a drain/refill at 50-60K? The fluid only costs $40-$45/gal from the dealer, and the Tacoma takes 3.2 qts per drain/refill.quote:
Ken
