Does anyone know if there is a replacement/equivalent for GM's Auto-Trak II transfer case fluid?
Or is it still dealer-only...
I've already had it changed once under warranty for the shudder on low-speed turns issue, but I thought it would be good to change every 30,000 or so, like the ATF, just to avoid problems in future.quote:
Originally posted by Mike:
There is no need to change it unless you suspect contamination.
