I did my tranny fluid change today and afterwards I tried to take a reading on the fluid level but I keep getting inconsistent readings. At first it looked like it was overfilled by a lot ( I removed 4 litres and installed about 3.75) but after a few more checks it looked like it was below the add mark. I then added about a 1/4 litre more. I then had to do a few more readings inserting the stick, and removing it. On the front side of the dipstick it reads full, but on the backside it reads add. If I flip the dipstick it reverses with front reading add and the backside reading full. I inserted and checked the dipstick about 15 times but still can't seem to get a consistent reading back to back. I am checking it properly with the engine at idle as per the manual. Only thing I can think of is that the dipstick hole is used for the filling and it may be holding some fluid on the sides of the dipstick hole/tube. The dipstick tube is curved which may create some of the issues. The clean fluid makes it harder to read too. I'll let it sit over night and check it again tomorrow morning.
any advice or experience on this would be helpful. Vehicle is a 2001 Caravan 4 speed auto, 3.3. L engine. thanks.
