JHZR2
Staff member
BMW folks swear by redline to quiet whiny rears. This is usually due to bearings, however.
Im my BMW, it quieted very slightly by changing from 75w-90 to 80w-140, not significant enough to make the change worth it.
Theoretically, the heavier lube ought to make fuel economy drop slightly. I didnt notice this in my BMW, though my driving profile changed somewhat.
Id also think that typically you'd want the smallest spread you could find. People want small spreadsin motor oil viscosity (i.e. 10w-30 instead of 0w-30), as the fluid won't shear down as much with use. Now, while a diff doesnt have as many points for shear to occut, Id imagine that the degree is MUCH higher, as you have a lot more power going through a smaller specific surface than on say, a piston in an engine.
JMH
JMH
