On the 2004 Classic (basically a 2003 Malibu with the 2.2L Ecotec instead of the 3.1L V6) GM recommends a 50,000 mile severe service interval (drop the pan, replace filter, refill). The transmission used is the 4T45E.
Would it be worthwhile to use a 30,000 mile interval instead?
Also, I have read in Popular Mechanics, of all places, that you can make dropping the pan much less messy by disconnecting the transmission cooler line from the transmission, extending it into a bucket, starting the engine and letting it run until you start to see bubbles coming out.
Is this an OK procedure to use for this transmission?
Finally, are there any known problems with the 4T45E or is this a reliable transmission?
