Here is one for the experts:
Is it possible to do a brake fluid analysis? I was thinking: since some perform engine/atf/gear/ps oil analysis why not to check a brake fluid for wear and contaminations? If I'm not mistaken most of the high quality brake fluid on the market is borate-ester based. What can we tell about a condition of brake fluid from analysis? What tests should be performed? Is it even possible to request such analysis from a lab like a Blackstone, Amsoil, or Shaffer's? Do we need a special kit for brake fluid or a regular oil analysis kit can be used? How much this analysis will cost?
Regards,
Regards,
