quote:
Originally posted by cousincletus:
I change tranny and diff oil every 25,000 miles. When I changed the oil in my Dodge truck manual tranny at 24,000 miles, the "lifetime" fluid (synchromesh fluid) looked like it needed to be changed and the magnetic drain plug had lotsa stuff on it. That's probably due to break in and the next time the plug will look better.
I changed the fluid in the rearend of my son's 97 Mountaineer. Specifically calls for 75w140 synthetic. Guess what? Only place I could find it was at the Ford dealer for $17.95 per quartquote:
Originally posted by **** in Falls Church:
According to someone involved in additive package formulation, OEMs will change synthetic gear lube suppliers for a difference of 7 cents per gallon.
You might consider using AMSOIL or Mobil 1 gear lube when you change, rather than the OEM. Probably cost less, too.
