Just wondering if anyone can tell me if there is any advantage to warming up an automatic transmission in Neutral as opposed to Park? We just had a cold spell of -40C weather and I was just corious....
Thanks!
Thanks!
Yes i believe it does becuase it cycles as soon as the engine is started.quote:
Originally posted by ZmOz:
Does tranny fluid heat up in neutral?
Why do most (if not all) manuals/dipsticks tell you to check ATF in neutral? If it's the same for the tranny I would think park would be safer while the engine is running...quote:
Originally posted by Kestas:
Park - Neutral...no difference for the fluid. They're the same thing except for the parking pawl engagement.
You're better off warming the fluid by driving the car.
Says right on my dipstick to check in neutral. Also says the same thing in the manual and my Haynes manual.quote:
Originally posted by Spector:
All of mine say park. I would bet most manufacturers would never get that manual past the risk managers if they said to check it in neutral, too many accident possibilities.
Says right on my dipstick to check in neutral. Also says the same thing in the manual and my Haynes manual. [/QB][/QUOTE]quote:
