I have changed the ATF in my 96 Corvette this spring with M1 synthetic ATF. I also replaced the filter with a new OEM unit.
Immediately after the change (full flush, drop pan, clean pan, replace filter, refill and flush soem more) during which I am sure I exchanged more than 95% of the OEM ATF fluid, I noticed that the part throttle shifts smoothed out significantly and the WOT shifts were as firm as before.
If you consult some of the internet forums (LS1.com, LS1tech.com, GTP forum and chevy truck forums), you will find the opinions split between synthetic and non-synthetic ATF. There is a whole bunch of people out there that claim the synth. ATF made their tranny slip, others say it works perfect.
Also, I struggle with Amsoil's claim for a universal ATF. We all know that the main difference in ATFs is the friction coefficient. Type F is the grabbiest ATF and oxidizes much quicker than newer fluids, Dexron is in the middle and Chrysler ATF+ is the "slickest" fluid out there (you can change Dexron to Chrysler ATF+ specs with the lube guard friction modifier). How can one ATF fluid serve all friction requirements. It just makes no sense. We know that plain unmodified Dexron often causes converter clutch shudder and clutch pack failures in Chrysler trannies. How can Amsoil ATF "serve all kings" here??
