What kind of gear oil would I need to use?
My owner's manual shows several different axles with different lubricants:
75W-140 synthetic for Visteon 8.8/9.75 (open and limited slip)
SAE 90 for Dana 9.75
80W-90 for Dana 10.5 and E-550 Dana 135
I need some Aspirin!!!!!
I don't have the van yet, but I asked the dealership to get one with the 3.73 limited slip rear end.
I have no idea what model axle it will be - what oil should I get?
Richmond Gear GL-6 75W-140 synthetic?
Or just Pennzoil GL-5 75W-90 synthetic?
My main concern is that this lube has to handle the abuse of a 5600+ lb van for hauling stuff, BUT if I get the wrong lube it should also be compatible with either my Ford 7.5" (used in my 3000 lb T-bird) or my ford 8.8" (used in my 4200 lb Crown Vic).
If I use the 75w-140 in any of the Dana axles, would I destroy something??
And what 75W-140 should I get? I found some Richmond Gear lube that looks promising.
