Hey guys.
For last couple of weeks I'm reading all the threads about intake valve carbon buildup and what oil one should use to minimize the risk.
I've found out about all the fancy words like low-SAPS, low-NOACK and bla bla.
Can someone explain to me as to a regular consumer - what is the oil to put into my GDI?
I run Pennzoil Platinum and Ultra (whatever is available at the time of an oil change), I saw some recommendation to switch to Total Ineo MC3 or other oil which is basically meets a diesel engine requirements (dexos2 or similar).
There's also all kind of other "Euro" oils, will I benefit from using it?
