Another option is to get another stock cover and have a fill bolt welded in. You would just have to calculate the correct position to drill and install the drain bolt, in order to have the oil level correct for the axle bearings.
This is only $9 Get another cover from a u pull it yard.
Have it TIG welded in.
https://www.ruffstuffspecialties.co...a2Q9Ph9YGTcD6xZ7yT-f6sqrQ6oaAuf1EALw_wcB
