Originally Posted by ugabulldog
so if I buy cheap gas (I buy it because it is cheap but also the freshest due to busiest station) and E10, then I should use a bottle of Chevron techron every 3k miles?
This is going to require you do a little math. It may be cheaper to run TopTier than purchase a bottle of techron every 3k on top of the cheap gas, just depends on how much you're saving by using the cheap gas.
