without amps, the small panels will not have enough power to push a car batt over 14.5V. Most of these are 5 watts, which is measured as a short for PV panels. The real time charge current in bright sun on a cold day might be 1/4 amp.
make sure the panel has a blocking diode to prevent discharge through the panel at night.
