Originally Posted by Duffyjr
I had bad luck with the china plug that came in my Toro mower. The first engine that came with one stopped starting on the first or second pull half way thru the first summer. Pulled the plug and it had black soot all over it which tells me it wasn't a hot enough plug. Put in a NGK BPR6ES and no more hard starts. Last thing you want is a snowblower that becomes hard to start when it's cold out.
You make an interesting point. I have two Honda GCV160 machines and two Chonda powered machines, including a snow blower, and all take the BPR6ES or equivalent Iridium BPR6EIX. The cooler F7RTC doesn't seem to make sense for this application. Cooler plugs are used for higher compression or turbo boosted motors, which isn't the case here.
That being said, the OP should give this machine a serious workout with the factory plug, then inspect it before changing the heat range.
