Hey,
I need to remove the rear differential fill plug but it's seized in, and is now rounded off even after using the proper plug remover tool.
I cleaned, wire brushed it, spray lube, torched it and put a [censored] of a lot of torque on it to get it out but it didn't budge, eventually rounding it off.
Since I don't have a welder I decided I'm going to drill the thing out and use a left extractor tool.
But I can't find a replacement anywhere online it's a 3/4 thread.
I believe it's the GM 8 inch diff.
I was thinking of using an alternative brass pipe plug such as this: http://a.co/d/gyg8V8J as a viable replacement option.
Any recommendations?
