Its odd since the Muranos I saw with high mileage were 07-08, and the Maxima I bought was an 09. I was thinking possibly more room in the engine compartment leads to lower temps and longer engine life on the Muranos.
Originally Posted by bbhero
Makes sense... About the tooling part...
I guess it can happen... I've read about the timing chain cutting into guides... But like you said it typically shows up "early". Well early compared to my miles
If you made it to 250k with no issues you're likely fine. Probably got one of those fresh new production run chains that didn't have the problem.
