Planning to do a fluid exchange on our Fusion which Ford specs as using DOT 4 LV brake fluid. I can get Pentosin DOT 4 LV locally for $15-18 for a liter. I'm not against Motorcraft fluid but it's twice as expensive from a local dealer ($16 for a pint). I did an exchange on my G35 recently and used less than a liter to do that. Did I get 100% of the old fluid out ? Maybe not but others with similar models (or 350Z models) indicated they used between 750ml to under 1000ml so I feel okay with the amount swapped.
Is this Pentosin good stuff ?
On a related topic, anyone use something like this DOT 4 LV in a car that only specs DOT 3 or DOT 4 ? Pentosin, for example, says it's backwards-compatible, even the LV variety.
