Originally Posted by Lubener
I go by the appearance and condition not age.
And the problem with that is that some tire manufacturers use a type of rubber on the outside that doesn't show what is happening inside.
In
The outside is what is exposed to the elements and UV light. I would believe that will deteriorate first.
The inside may be exposed to moisture, even more than the outside.
In
