Originally Posted by Warstud
Does that fitting on the vac hose come with the Flo N Go ?
Yes it does, and concentric with it is a smaller inner ring to fit the next smaller vac hose. The only item I had to buy was a 10 ft long piece of 3/8 " OD plastic tubing which cost 5 bucks. The 10 ft of tubing gave me enough length to reach from the garage floor up over the vehicle fender, over to the tranny fill tube and down into the fill tube to the bottom of the tranny oil pan. The plastic tubing that came with it was only a few feet long.
