I think at the end of the day, it boils down to your car, your business. IMHO, OE isn't always the holy grail it's hyped up to be - think of the nylon timing chain tensioners, or all-plastic intake manifolds Ford used at one point, which turned into a class action lawsuit as one example, or the Multec injectors GM used on the Vortec 7400 454 big block in the 90s. Even Mercedes-Benz wasn't immune with their balance shaft issues in their M272 engines that also turned into a lawsuit. So I apologize for not buying the whole "they had a reason" thing.
Reminds me of the airline industry/lobbyists in a way - if the Government is covering your airfare, they'll put you on a "flag carrier". I've been in that situation multiple times where the so called "flag carrier" does not happen to cover my country of departure and I'm put on a "Star Alliance" Lufthansa or "SkyTeam" KLM flight (including the connecting flight) with United or Delta printed on the boarding pass. If you were to buy that exact same ticket from KLM, you would pay $1,150 but the Government instead pays $2,342 for a Delta "flag carrier" ticket and you're not even in Economy Comfort for that rate. Sure, they had a "reason", but that "reason" may not always be what you think. Just my
