Hello Everyone,
I cannot seem to find the answer to this anywhere and was hoping someone would know the answer:
I have a 1999 mazda miata, I am fairly certain it has an open diff (non-LSD), I have only been able to find Mobil 1 LS 75W90, I am assuming the LS stands for limited slip. Is it a bad idea to put this in my differential or will it be ok? If its a bad idea, any recommendations on a good brand to go with? I have had some bad luck with Redline in the past. Thanks!!
