2nd oil change in 8000 kilometers. I sent it to another lab. They initially had an issue when using a baseline sample I provided but got things corrected. Wear metals have come down to around 25-33% of where they initially were at.
Just goes to validate that it isn't a bad idea to change your oil in a new vehicle, or new engine at an earlier interval than what Oil Life Monitor recommends.
Hopefully this fuel dilution gets better with the next oil change. It has dropped substantially from the first one. Maybe rings are seated in better now.
Fluid Life 3904km-----------------AGAT 4096 KM
Sodium 7------------------------------------------3
Potassium 4-------------------------------------1
Silicon 82 (reportable)------------------------24
Aluminum 5-------------------------------------3
Iron 32-------------------------------------------16
Copper 59 (reportable)----------------------19
Lead 2------------------------------------------0
Tin 0----------------------------------------------1
Chromium 1-----------------------------------1
Nickel 0-----------------------------------------1
Titanium 0-----------------------------------na
Silver 0-----------------------------------------0
Vanadium 0-----------------------------------na
Antimony 0-----------------------------------na
Berylium 0-----------------------------------na
Calcium 2090--------------------------------1860
Zinc 768--------------------------------------762
Phosphorous 704--------------------------------593
Magnesium 16-----------------------------------7
Manganese na-----------------------------------4
Molybdenum 71------------------------------145
Boron 158------------------------------------54
Barium 0----------------------------------------0
Lithium 1---------------------------------------na
Visc 40C 47.8 (reportable/ typical 65)----------46.6(lower Critical)
Visc 100C 8.29 (reportable/ typical 10.8)--------8.7 (lower Reportable)
Visc Index 149 (typical 157)-----------------------na
Fuel % 8.47 (Unaceptable)------------------------3.4 (Upper Critical)
