Originally Posted by LeakySeals
Interesting core. No metal, no holes. Flow must be good. But that design looks like it provides minimal support to the media under pressure. "What if" some of the wet loaded media was to break loose or get sucked through the center tube.
Media "blow through" could happen on early eCore center tube designs when the window size was larger. But they have reducrd the window size which seems to have cured the problem.
