Lotus OEM oil filter, appears to be a Denso. I had bought a case of these and noticed that this one had a Toyota p/n as well as the Lotus one. I may go w/ the Toyota filters going forward, although the Lotus ones aren't that expensive.
~2K miles, Redline 5w-40, nothing in pleats
Well made filter. Can isn't as thick as the Mann or Mahle, but otherwise fine. Media is one piece and has plastic or hard adhesive rings molded at the ends that slide on the center tube.
