Running a remote ATF filter plumbed into the aux atf cooler in my F150. Last fluid change was about 80k miles, filter added at that time. Now 102k miles and I did a pan drop along with a replacing the Napa Platinum remote filter. Here is the old one. Looks to me like it is fine for a much longer service interval. It is mounted in a fairly exposed location, though, and has developed some minor corrosion around the crimp seam.
FWIW, I was a little torn about which forum to post in, since this is, technically, an engine oil filter. Being that its used for a transmission filter I am posting here.
