Extended Oil Drains
by The Critic. 11/20/18 12:08 AM
Extreme not maintained
by tiger862. 11/19/18 10:52 PM
Remember when the year 2000 was the future?
by PeterPolyol. 11/19/18 09:38 PM
Supertech Syn in new tgdi?
by BTLew81. 11/19/18 09:06 PM
New Hemi 5.7 - Oil Suggestions?
by Greg L. 11/19/18 08:53 PM
Fluid Change on Chrysler 9 speed (ZF) trans
by 92saturnsl2. 11/19/18 08:41 PM
New tire size, new tire pressure?
by Melectric. 11/19/18 08:40 PM
Pep Boys Black Fri M1 $19.98 5 qts
by tenderloin. 11/19/18 08:10 PM
Supertech, first time
by buck91. 11/19/18 08:07 PM
Throttle frozen after sitting a few months
by atikovi. 11/19/18 08:07 PM
How much $ to have your own brand?
by Red91. 11/19/18 07:43 PM
Used blizzaks
by Ndx. 11/19/18 06:47 PM
Federated PG111F Cut Open Jeep 2.5
by troutfisher. 11/19/18 06:06 PM
2013 Ram front fender rust
by irv. 11/19/18 05:50 PM
Pro Motive PH 241 CUT OPEN
by 53' Stude. 11/19/18 05:27 PM
Mobil 1 FS Differential fluid
by bobbyjoe. 11/19/18 05:20 PM
Car randomly switches off
by Spetz. 11/19/18 05:16 PM
379exhd, Drew3419, KevinGC, Jaygee, bryanmacb
66478 Registered Users
37 registered members (bbhero, ArrestMeRedZ, bamorris2, 2015Corolla, aleneros, 2 invisible), 923 guests, and 25 spiders.
Topics293,810
Posts4,904,903
Members66,478
Most Online2,553
Oct 27th, 2018
How To Choose The Proper Lubricant #4918592
11/08/18 03:03 PM
11/08/18 03:03 PM
Idaho
NateR Offline OP
NateR  Offline OP
Idaho
Hello,
I've been getting into automotive repair on my own car over the past couple years (basic stuff - brakes, changing fluids, replaced a thermostat, that kind of stuff). This next weekend I'm planning on swapping the window regulator in my GF's car as well as taking a look at her other windows running slowly and her driver door latch sticking when it's sub-freezing. These tasks are going to take some lubrication, and I asked on another discussion site which ones are suggested. I was told dry silicon lubricant for the rubber window tracks, and "traditional grease" (which is...?) for everything else.
This has prompted me to read up on the types of lubricants. I was aware of greases, oils, and dry lubricants, and have a vague idea which category to use for various applications, but within those categories I haven't the foggiest idea how to settle on the right kinds. Take greases for example - I've seen lithium grease, silicon paste, moly grease, all-purpose grease, and a whole pile of others. When would each be used? I know that in situations where contact with plastic or rubber, or in high heat situations, I would want to utilize special kinds, but beyond that I'm lost. I've started collecting a few kinds for the various jobs I've done simply based on what was recommended by the people whose videos I watched or general recommendations online. However, I don't know in what other situations these would be useful, and I've probably got overlap in the lubricants that I've purchased. I would like to be able to know what kind of lubricant to use in various situations, rather than spending a bunch of time reading online for each specific job I run into.
Any good resources for someone new to mechanical stuff? Searching online most that I'm seeing are throwing out a lot of terms I'm not familiar with, making it obvious I'm not the intended audience. Is there a good "idiot's guide to lubrication" (along with a fairly complete list of lubricants I would find useful in automotive and homeowner situations).
Thanks, all - I figured if anyone on the internet could point me in the right direction, it'd be you guys (I spent a lot of time lurking here, reading up on motor oil before deciding on a brand).
Re: How To Choose The Proper Lubricant [Re: NateR] #4918599
11/08/18 03:14 PM
11/08/18 03:14 PM
Illinois, U.S.A
RamFan Offline
RamFan  Offline
Illinois, U.S.A
Definitely will be following this thread. For as much time as I spend on this forum, I've only barely dabbled in the grease section. Looking forward to the responses.
18 Giulia Ti Sport
+2.0l turbo - 3k - PP Euro LX 0w30 - Mopar - 10k/1yr
16.5 CX-5 Touring
+2.5l - 50k - SynPower w/ Maxlife 0w20 - PureOne - 8k/1yr
Re: How To Choose The Proper Lubricant [Re: NateR] #4918600
11/08/18 03:17 PM
11/08/18 03:17 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
People get a bit crazy talking about grease and oils. Personally, I don't think the difference between the best and the merely serviceable is all that large. Whatever grease you get will probably be a lifetime supply unless you buy the single dose packet.
Don't sell yourself short, changing out a thermostat is more than basic stuff. Filling up the windshield wiper reservoir is basic stuff.
Have you changed out a window regulator or opened up a door before? Get one of those trim removal kits with the plastic pry bars and whatnot. And watch the sharp edges inside the door. I was covered in little cuts last time I messed with the inside of a door.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: How To Choose The Proper Lubricant [Re: NateR] #4918623
11/08/18 03:43 PM
11/08/18 03:43 PM
N.A.
Onetor Offline
Onetor  Offline
N.A.
I would suggest an opening paragraph. Then your list of questions. Welcome to BITOG NateR. There are some truly gifted people on these forums that can answer your questions, so I defer to them.
Re: How To Choose The Proper Lubricant [Re: NateR] #4918643
11/08/18 03:58 PM
11/08/18 03:58 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
Have you tried silicone spray in the window tracks? I had slow rear windows and lubing up the rubber tracks helped.
2018 Hyundai Elantra VE -- 5K
2013 Honda Pilot EX-L 4WD -- 57K
2002 Honda Accord EX-L -- 212K
Re: How To Choose The Proper Lubricant [Re: mclasser] #4918908
11/09/18 01:08 AM
11/09/18 01:08 AM
Idaho
NateR Offline OP
NateR  Offline OP
Idaho
When I was doing out my original post, I was kind of wondering if I was overthinking it... but I'm too much of a perfectionist to go with "merely serviceable" much of the time smile
Thanks for the suggestions! I do have some plastic pry tools - the last couple things I've done with her car involved prying plastic trim pieces, so made sure to have those. Regarding opening a door, I had not until I pulled the regulator from a car in a local junkyard - and an added (big) bonus to getting cheap parts that way is I have a trial run on a car that doesn'thave to look pretty when I'm done laugh
Hmm... unfortunately I don't see an edit button... is there a time limit to how long a post can be edited?
I have not - this will be my first go at it. Thanks for the suggestion! How well would a standard silicon spray work vs a dry silicone spray?
Re: How To Choose The Proper Lubricant [Re: mclasser] #4926597
11/17/18 06:02 AM
11/17/18 06:02 AM
South Carolina (SC)
RyanY Offline
RyanY  Offline
South Carolina (SC)
^this.
I like to clean the tracks first with a shop towel and alcohol. Just fold it thin and insert into the track and move it up and down. Then either spray the sili onto another towel or spray directly into the track. Should last a few years before you have to repeat.
Regarding the latch, it is usually best to clean them first (like most things). I use penetrating oil as a cleaner, which I let soak for a few min or longer depending how gunked the latch is. I then blow out the gunk and oil with air compressor. Then its ready for lube. White lithium grease is excellent for this purpose, but only if you have a light colored car. Otherwise your hinges will be caked with white grease! For my cars (all of them are black), i use a lube made for the purpose, such as GM Super Lube 12346241. It goes on like WD40 but thickens to a layer of grease. I have found it to last a long time, but that depends on how dusty your conditions are and how often you wash the car. This lube would also work well for virtually everything inside the door.
2007 Cadillac CTS 3.6L >117k miles (Castrol Magnatec 5W-30)
2012 Honda Odyssey EX-L >91k miles (Pennzoil Platinum 0W-20)
