Shell Rotella Gas Truck Oil
Lakeland , FL
I searched for threads but , didn't see any. sorry if this a double post.
If somebody could find out what viscosity the different grades are that would be cool. I couldn't find much.
Shell Lubricants is introducing Shell Rotella Gas Truck full synthetic engine oil providing, extreme protection for towing and hauling for gasoline-powered pickup trucks and SUVs. The oil, from the makers of Shell Rotella heavy duty diesel engine oil, offers the unsurpassed protection these engines need in three viscosity grades: 0W-20, 5W-20 and 5W-30 beginning in January in the U.S. and in May in Canada. The oil will be available in 1 quart, 5 quart and Ecobox in the U.S. and 5 liter in Canada.
"We're excited to introduce an oil for pickup trucks and SUVs that meets the demands of modern and older gasoline engines," said Megan Pino, Shell Rotella global brand manager. "We have more than 40 years' experience protecting hard-working engines, so we understand what kind of operating conditions these vehicles are likely to face. Whether being driven for work or fun Shell Rotella Gas Truck full synthetic engine oil works hard to protect and prolong engine life for all new and older trucks and SUVs."
Shell Rotella is the first major oil brand to introduce a complete portfolio of full synthetic motor oils for both heavy duty diesel engines and gasoline-powered trucks and SUVs. All three grades of Shell Rotella Gas Truck motor oil are formulated to provide unsurpassed wear protection in even the most extreme conditions trucks and SUVs face, including heavy hauling, towing, extreme temperatures and off-road. The synthetic base oil delivers added oxidation stability, improved volatility and low-temperature properties.
Shell Rotella Gas Truck is recommended for use in gasoline-powered pick-up trucks and SUVs, including those that experience more extreme conditions, including driving with heavy loads, stop and go driving, frequent short trips, extreme hot or cold temperatures, and extensive idling. The oil is approved for use in Ford, GM, Ram and Toyota gas-powered trucks and SUVs.
Shell Rotella Gas Truck 0W-20 and 5W-20 full synthetic motor oils help protect engines in extreme temperatures and conditions and outperform conventional motor oil in severe driving conditions providing unsurpassed wear protection and helping prevent sludge and other damaging deposits. Both oils meet API SN PLUS and API SN-Resource Conserving and are ideal for modern turbocharged engines. SAE 0W-20 and 5W-20 viscosity grade oils are commonly recommended for use in many new vehicles with modern engine technology for maximum fuel economy and performance.
Shell Rotella Gas Truck 5W-30 is recommended for use in vehicles requiring the use of SAE 5W-30 viscosity grade engine oil under all driving conditions. The oil is ideal for pick-ups and SUVs that may experience more extreme conditions including driving with a heavy load, in dusty conditions, stop and go driving, frequent short trips, extreme hot or cold temperatures, and extensive idling.
https://www.oilandgasproductnews.co...s-synthetic-oils-for-gas-powered-pickups
https://rotella.shell.com/en_us/products/gas-truck-synthetic-engine-oil.html?gclsrc=aw.ds
[Linked Image]
Nice marketing. Although I'm certain it's good stuff. Too bad I bought some Pennzoil High Mileage for our Focus yesterday. If not I would give this stuff a try.
Good scoop! They might have a slight amount of demand destruction because the Rotella T6 5w30 mult-fleet is already SN rated, but yes, good idea. Haven't see the vis numbers yet. Thanks for the informative post.
I'd really like to use the 5W30 specified for the 2019 Ranger I'm buying. It has the Ford WSS- WSS-M2C945-B1 approval
Looks like 0W20, 5W20, and 5W30. I still bet that T5 and T6, even though they no longer have gasoline engine approvals, will be better (& CHEAPER) than this new oil. Bottle looks a lot like MaxLife as well!
Mostly correct but 5w30 T6 Mult-Fleet is still rated SN.
Looks like Maxlife? Lol I mean by that logic Motorcraft oil also looks like Maxlife because the container is red too? Lol.
As for gas trucks, I'll stick to Delo for my 276k mile Silverado.
Quaker State 4x4 from the 1990s returns again. Oh SOPUS...
But no API starburst - there must be something tweaked.
Not the first as claimed. Mobil 1 had a "Truck & SUV" oil that they discontinued 10-11 years ago or so. IIRC, it was only offered in 5W-30.
Hi @JohnD2, great questions! Shell Rotella Gas Truck Motor Oil will be available in full synthetic 0W-20, 5W-20, and 5W-30 viscosities. SAE 0W-20 viscosity grade oils are commonly recommended for use in many new vehicles with modern engine technologies. 5W-20 and 5W-30 viscosity grades are recommended for use in vehicles under all driving conditions particularly gasoline pickup trucks and SUVs that tend to experience more extreme conditions. Hope this helps!
Do you have a technical data sheet link for this oil ? Thank you for your time.
